diesel rattle in D4D Prado
This is a sticky topic.
  • I have heard the same the a fix is coming to upgrade the computer that will better distribute the fuel when cold, however the injector replacement has fixed mine for now
    2007 Prado D4D GXL - Waeco 50litre - Dual Batteries 105ah- Redarc Smart Start - Customline Camper Trailer(3rd 105ah battery) - 2 inch Ironman lift kit - BFG's 265/70-17
    Wish List (Snorkel - car topper boat with 5hp)
    • Diesel engine clatter
      Originally posted by Crammy
      Originally posted by RUSTY
      Hi Rattlers, Got a call from my dealer today, after sending my data to toyota they asked me to bring it back in about 3 weeks, once the big knobs given them the go ahead.They all got together on the weekend and desiged that this problem is not going away. So now iam getting the reflash ; then 1000km of driving ; then check all the injectors & replace any that are faulty.I think this is the stage most of us are at. I was told that the ECU is the problem it is not sensing the cold start there for pumping to much diesel into the chamber which causes the pinging or rattle we hear, this is dirtying the injectors. The idea behind the 1000km of driving is to clean them? This is what i was told today . My rattle is only there at a cold start not at normal operating temp unlike some you, so hopefully the refash will do the trick.They also said they are only getting in touch with the people who have complained so i dout if there is going to be a recall on all d4ds. I will keep you all posted, Russell.
      Interesting info there Rusty. When I spoke to my dealer they said they had sent the data off to toyota and not a week later they said they will replace No.2 injector and "we'll see how that goes" to fix the problem. There was no mention of a reflash in my case. My rattle got progressively worse to a point where now I can hear it when up to temp. Maybe there are a few different issues at play here. 1 - Being a programming issue and 2 - an injector issue or 3 - maybe both?
      With the weather warming up here in Cairns (Cold start a balmy 24-25 degrees this morning) I have noticed it's not as pronounced on cold start but is still there none the less. But when up to temp it is louder than ever.
      Crammy
      :roll:
      Well PradoPointers, I am able to add another scenario regarding what is causing the "clatter", mainly when cold.
      When I dropped my vehicle off at the dealer this morning to have a SECOND set of engine mounts replaced under warranty, I spoke to the ser vice manager re the cold clatter and he advises it is caused by uneven action of injector cleaner!!! Apparently, different brands of diesel have different levels of a cleaner additive and depending on this, the injectors do not get cleaned evenly and level a mior carbon residue, hardly even distinguishable when removing and looking at the injecor at fault. I guess this could explain different injectors being responsible, as reported by previous posts? In any event, the service manager told me that it will go away after a while and not be a problem (after enough fuel has been forced through to remove the residue). This is indeed the case with my vehicle, I had a run of it and it has now gone. At least I hope this is the case, the dealer is happy to see and assess the vehicle should it happen again.
      He also indicated from his experience, there is one brand of fuel common to the majority of cases he has encountered. Gary :roll:
      2007 Prado Grande
      • Thanks for the info gary. If the dirty injector is the cause you would think they'd run some injector cleaner through to fix the problem.
        Mine has been happening for around 6000kms now with no signs of going away, infact I rekon it gets louder by the day... Anyway should be back to 100% Monday hopefully!
        2008 GXL M6 D4D, Silver
        • I love the way all these dealers have a different take on what is causing the problem. There was no way my injector was going to fix itself and only replacing it cured the problem.
          Pradopoint GTG website:
          My Weather Station In Alice
          My photo website:
          • Got mine back yesterday from the dealer. Was told that they will send the report off to toyota and toyota will send them a new ECU and a set on injectors once a kit becomes available.
            They recon they are waiting on 8 kits before mine, mainly for hilux's but some prado's as well.
            • Also booked in for Monday for injector #4 replacement, interesting the roving Toyota technical guru wants to be there for my injector change over. I'll update Monday night.
              cheers
              mardo
              08 D4D Auto
              • Hi all,
                So our Prado is in today ... Engine mount replacement and ECU Flash/Injector check.
                So update so far:-
                1. The pre- ecu flash injector check
                i1 : -1.1
                i2 : 3.2
                i3 : -2.5
                i4 : 0.4
                Outcome: Toyota (not just dealer) recommending 4 new injectors required. And this must be done prior to the ECU reflash now.
                They noted that there are now revised injectors ie "new design ones" but availability is an issue (possible end yr availbility, although this may improve)
                A note was also made that ALL additional accessories added to car need to be disabled/disconnected prior to ECU re-flash - anyone else heard that? (I have indicated that is toyota responsibility to do!!!)
                So saga continues for longer!
                Borgy
                Prado VX Diesel 2007 Silver
                Lots of add-ons...
                [url=http://autos.groups.yahoo.com/group/aussieswag/join][img]http://autos.groups.yahoo.com/group/aussieswag/[/img][/url]
                [i]Click to join aussieswag[/i]
                • Borgy what's the go with the engine mount issue? Is it rattly under load?
                  I'm trying to find another bad rattle I've got which appears under load in most gears include LR.
                  Good to hear that toyota is looking after you. I haven't heard anything about a reflash from my dealer. Either they're deliberately not telling me anything or they don't know. I can't even get the injector feedback figures off them!
                  cheers,
                  Crammy
                  • Hi
                    It sufaces as a noticeble shaking just before you stop and at very low/crawl speed (idling)... I am the 3rd prado that this dealer has dont engine mount replacements...
                    Push for them that way there is a clear record of what was found and their recommended action.
                    Lets hope this get consistently addressed in a more widespread fashion!
                    Borgy
                    Lots of add-ons...
                    • Re: Diesel engine clatter
                      What brand of fuel :?: You can PM me if you like, Thx
                      2000 Toyota Prado GXL- Gone, but not forgotten...
                      '92 Landcruiser HDJ80 4"lift 33's
                      '91 Surf LN130 coil sas, 4.8s, 35s
                      '12 Jayco Eagle Outback
                      • Originally posted by timbo_gxl_d4d
                        Wed 1st October
                        I have the car back but they are doing a warranty claim now on injector number 3 this time. The process is they get the data, send it off to Toyota. Toyota looks at the data, decides on the warranty claim and sends out a new injector if the injector is out of tolerance.
                        Got the call today, they are replacing another 2 injectors (and the seals and the injector lines). Hopefully it goes well and the "pride and joy" can become fun to drive again.
                        The car goes in on Monday.
                        Tim
                        2008 GXL D4D M6 Silver. Mickey Thompson Baja ATZ 5 Rib Tyres, Sovereign Bull Bar, ScanGuage II, Old Hella 140 Driving Lights, Milford Cargo Barrier + more bits waiting to be bolted on...
                        • reflash
                          Hi boys,
                          the truck goes in on Monday for the reflash and injector change, i will keep you posted on the results.
                          Babs
                          2011 VX D4D
                          • Originally posted by Crammy
                            cheers,
                            Crammy
                            Hi Crammy,
                            Is your rattle at about 2200RPM when changing up gears. :?:
                            • Nah mate, pretty much off idle up to around 1500-2000rpm. 1st and second gear mainly, but 3rd as well if I'm being lazy with the gear changes.
                              Oh and in LR also.
                              • Picked her up today after injector #4 replacement, ahhhh.... nice and quiet. I was fortunate to catch up with the Toyota Technical guru who authorises such injector warranty claims to asked how it went.
                                He said, as well as the injector replacement, he performed a ECU reflash with modified parameters that now have a self clean functionality included. He wouldn't go any further on how and when this functions works though. Anyway, running like a dream, so far!
                                cheers
                                Mardo
                                08 D4D Auto
