Genuine DLC ( upgraded ) injectors are available through me from Toyota NZ
The kits cost is $2065 NZ ( approx $1765 AUD ) delivered to your door on a 2-3 day service from NZ
add on a couple of hours to fit and code to the ECU and your done!
So for around the $2k mark - you can buy your own new DLC injectors injectors and have them fitted
Kit includes 4x DLC injectors inc seating washers , 5x return line washers, and 4x fuel pipes
(your dont get pipes with recond or blueprinted injectors)
Pipes are a MUST replace if the injectors have been moved (ie replaced or seating washers done requiring injector to be removed)
I have supplied 3 sets in the 10 days to PP members
