Question: Is the 22nm torque for the injector clamp a dry or lubed value?
The shop manual will specify whether the fastener is supposed to be dry or lubed. In either case, prep your bolts. Don't forget that residue from the parts washer or that pie tin full of kerosene you're using to clean parts has oil in it. Even a quick blast of compressed air to dry off a fastener will leave an oily film behind, affecting ultimate torque. If you're really fastidious, clean up with some aerosol carb or brake cleaner, followed by more air.
