Since the customer service exercise here about feb 2015, (7 years overdue) we have seen a huge reduction in the usual problem, blow by,
At the injector due to copper seats leaking, blocking oil pickup, starving the engine of oil/lubrication.
So this means Tojo have worked on many more of them before us 1kd injector experts get a go at them.
Before it was blow by city! Untouched, unbutchered.
Now, not much blow by, but the list of damage is on the increase. This includes other trusted workshops.
Don't get you mankini in a knot, some workshops, Toyota dealers & techs are good, I'm sure, well I think, I'm told........
No really I'm sure there are good ones.
Anyway myself & other expert have names for some of the common problems & I'd like to share so you know what Im on about.
JACK IN THE BOX
when Tojo bend the fuel pipes to save time removing from common rail.
It's been going on for years, but increased substantially in the last 12 months.
We release the top of the pipe, with trouble due to bend pressure & boing boing boing......![](https://www.pradopoint.com.au/core/images/smilies/icon_wink.gif)
LEOPARD SPOTS
wen many workshops put injectors back in on dirty ports.
Dirty port
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/53D5E1A5-D525-4156-85EF-5A8C6D5DB6CB.jpg)
Clean port
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/B4002FB5-C9E3-400F-91D1-A549A90C03C8.jpg)
Leopard spots
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/A3B7DDCF-115C-431D-B1A6-2279E3F88706.jpg)
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/52ABC139-D8E5-4C58-8698-1C809FE7A416.jpg)
This set put back in after 40k valve clearance, place in Qld non Toyota, Sunshine Coast, JUST can't remember the name.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/C2B2AEE3-7A1C-4800-87AC-4C6B9A810653.jpg)
I have seen this procedure cause blow by in no time! With the revised coated seats, it has cost turbos & bottom ends. NOT GOOD.
Here you go, see for yourselves
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/92F7F6C6-0329-4E3B-9822-D87EEDB0158B.jpg)
The only way to replace injectors is in sets, often Tojo replace 1 or 2.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/08EF0C45-E68F-4FE4-AC60-13AD3570FBEC.jpg)
They didn't even bother to remove the others & change the seats.
Which means they didn't do the valve clearance check while in there.![Confused](https://www.pradopoint.com.au/core/images/smilies/confused.png)
The Toyota workshop manual states, new injectors - new pipes. Only a very small percentage get new pipes.
Tbc
JACK IN THE BOX
![](https://www.pradopoint.com.au/core/images/smilies/icon_biggrin.gif)
LEOPARD SPOTS
Dirty port
Clean port
Leopard spots
Tbc
