Haven't posted in ages but was wondering if any body has slotted a engine from a Hilux d4d into a 120 Prado with a buggered d4d.
Manufacturers always seem to change stuff even if the engine is the same being 1kz-ftv. Might be the cheapest way to fix buy a statuary write off with low ks. I know the sump is different. Me thinks the rest should be similar, sit both engines on the floor swap the gear over from one to the other
