Not another EGR thread
  • Not another EGR thread
    Afternoon,
    Quick query, I have searched the forum and cant find an answer. Does it matter which end the egr restrictor plate goes of the cooler?
    Can it be at the egr valve end?
    Originally posted by Gudgeon_pin View Post
    Afternoon,
    Yes.
    No.
      I put mine at the valve end.. read somewhere afterwards that you are meant to put it at the other end but it's been on for a few hundred K's and not had any dramas... was a tricky job so be prepared to spend a few hours doing it and giving the EGR and inlet pipe a good clean...
        OK cheers, I'll follow the tried and tested way and go the engine end.
          Yep. The front end, right next to the water inlet/thermostat housing.
          Stan Miko
          - 2007 120 Series 3.0L D4D
