1kd-ftv Cat Converter
  • 1kd-ftv Cat Converter
    According to my car manual, the 1kd's have a cat converter. Do I need to use a specific engine oil?
    From what I gather, the pajero and pathfinder diesels need some expensive synthetic stuff because of the emmision system.
    Re: 1kd-ftv Cat Converter
    Hi gxl_d4d
    without going into too much detail, the "Cat" is a catalytic converter - primarily responsible for breaking down the nitrous oxide and carbon monoxide exhaust emissions into less harmfull products (water, oxygen, nitrogen, carbon dioxide).
    Some cars have a diesel particulate filter - (the pajero has one from memory) - and this is aimed at stopping the soot (carbon particles) from being emitted. That's the black smoke you see belching from some less than efficient (overfueling) vehicles. Soot contributes to smog.
    more info can be found on: http://autospeed.com/cms/A_108104/article.html
    As for oil types - not an issue for cats - only for particulate filters so basically for yours (and my) D4D - a special oil is not needed as the Prado's dont have a particulate filter.
    Have a read on PP about oil types. there's a lot of info there and the owner's manual gives an indication to the grade of oil required.
    regards
    Michael
    Easter-08 White GXL D4D Auto - delivered in near record time (5d) from placement of order. Has turned into a "Bermuda" or "Swiss fund" where $ get lost or converted into mods/accessories.
