Hey guys one for us that have the old version oilr i have a rattle under the hood which occures exactky between 1300 and 1400 rpm i cannot duplicate with my head under the hood so it is only under load everything mechanical seems OK seems more like something loose have checked it over but can find no obvious suspects any edxperiences or ideas would be appreciated
Rattle Under Load 1KZTE
I had a ratlle under load as well. I found it by getting my wife to put it in drive 1 foot on brake 1 foot on accelerator until it happened and then searched around until I found it. My rattle was coming from teh right hand side panel just behind the headlight. some double sided foam tape fixed that sucker right up.Andrew
2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
[URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
[B]Bitumen - A blantant waste of taxpayers money![/B]
[URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
Hi Fellas. My 1KZ-TE also has it. It almost sounds like a diesel pipe vibrating. I would put it at the left side of the vehicle. It only appears under low rev's and on load. I would love to put it on a dyno for a while and have a bit of a crawl around but too expensive to just cure a rattle. What makes it worse is the old trout can't hear it - say's I'm losing it! Will follow this thread with interest. Cheers.2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
Heat shield on the exhaust? I had a really tinny rattle in my old 1.8L corolla at 2200rpm but only when under load and it turned out to be a heat shield.[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
