Advice needed
  • Advice needed
    I have a 2005 GXL TD manual with about 36000 km. Almost since new it will increase engine temp. as I drive up long step hills. This usually occurs as I cruise at 100/110kph and try to maintain that speed with the cruise control. It mostly does. The gauge is normally a bit over a third and moves about three needle widths to about half. It returns to normal soon after the hill. I thought it was normal as a diesel produces more heat as it gets more fuel. It came up in conversation when I was researching ECU chips for the car and one of the guys thought that Toyota cooling systems should be able to handle the extra work on the engine. Any Gurus with advice?
    Garry
    2008 GXL D4D Manual, ARB Delux Winch Bar, IPF XS800, Dual Batt, 50 mm Kings + Bilsteins, Firestone Airbags, TJM Bashplate, GME TX3420, Trak Tech drawers + cargo barrier, LongRanger 21lt water tank, Rhino Rack, Airtec Snorkle, ARB Compressor, Polaris Awning, DP Chip, 2.75" Beaudesert Exhaust, 12000lb Runva Winch
    mine moves under load, e.g. climbing a hill offroad that is generating some wheelspin.
    but i would assume, that if it is dropping back down after the hill, then the cooling system is doing it's job!
      Same with mine when i tow my boat. Don't remember if it did that before i got my spot lights on the bar.
      2006 TD Grande
      ARB Winch Bar. Rallye 4000's
      GME TX 3400
      BF Goodrich 265/65/17
        Mine does it also when towing, but I also have a auto.
        All engines temp will move as the load changes on it.
        The more fuel (load) the bigger the bang, the bigger the bang the more heat and opposite with less fuel less bang
        Even the V6's will do it, you might not see it but they will
        Craig
        03 GXL TD, factory bull bar,cooper ST's, dual batteries, IPF 900 HID spot lights, kingsprings, koni shocks, DP chip,hilux wiper jet upgrade,ATS bash plate, Snorkel, front recovery hooks, custom 3"dump pipe, 3" exhaust, ARB Compressor, ARB rear locker
          My Pajero Turbo Diesel did it,
          My 80 series Landcruiser Turbo Diesel did it and
          My '06 Prado Turbo Diesel does it.....
          I start worrying when the guage creeps up past halfway
          '06 120 GXL TD ARB bar, IPF Spotties, UHF, D694's... More to come
            Garry, I wouldn't be too concerned. Mine does it, too. And when I had the camper trailer it didn't seem to make any difference.
            Driving around Sydney the last couple of weeks when the temps have been in the high 30's, or even low 40's last Saturday, I noticed the temp went to 1/2 way and the fan ran almost continuously.
            I reckon it's good to see the car has a cooling system which is capable of keeping temps in the mid-range even when hot (43 deg last Sat!)
            [i]I remember when sex was safe, and flying was dangerous![/i]
              Advice needed
              Thanks every one for your responses. It is important to me to get a feel from people who drive our vehicles rather than rely on the Toyota Servicing people who have a vested interest.
              I am preparing for a trip up the Canning Stock Route in August and I want to make sure I fully understand what my car does. It will be interesting to see what happens when I fit the ECU chip.
              Regards
              Garry
                At least you have a temp gauge that actually works with each degree that it goes up. My last car was a Surf 2.4, and they were fitted with a 3 stage gauge. They moved from cold to normal, normal to hot, then from hot to too late !!!
                I like to see my temp gauge work these days. 3 grand to keep the surf cool convinced me to trade up :shock:
                cheers
                Les
                LES
                [url=http://www.brisbane4wdclub.org/index1.htm]Brisbane 4Wd Club Inc[/url]
                [url=http://www.brisbane4wdclub.org/images/avatars/mystuff.htm]MY STUFF[/url]
