A pretty simple question, I have searched and not found much info about my particular question.
I have a D4D Prado and a couple of months back got ARB to install a Safari snorkel.
Since the snorkel was installed I have noticed a lot more induction noise, especially in the higher revs. To me it almost seems breathless when its approaching 3500rpm, the sucking of air is quite loud, and seat of the pants says it doesn't go quite as well.
I saw the pics of the tubing that goes in the inner guard to connect the snorkel, its does look more restrictive which is probably the reason I am hearing the sucking noise.
Is anyone else experiencing this type of noise at higher revs under load?? To the best of my knowledge, this induction noise (sucking of air) didn't exist before the snorkel.
If its not normal, what could be causing it?? I found some reference to the little grill on the air ram being loose, I checked that, and it doesn't seem loose.
Any input greatly appreciated.
Andrew
Andrew
