Changing Drive Belts - D4D
  • Changing Drive Belts - D4D
    I am trying to mod up an endless air set up and I really should know this for outback travel anyway but - need some advice. What is the best way to change the serpentine drive (fan) belt? Do you have to remove all the belt tensioners to get enough leeway? Any tips would be appreciated.
    DocK
    2007 Prado VX D4D, With a lot less options lately!
    Re: Changing Drive Belts - D4D
    I downloaded this some time ago and it might be just what you want :wink:
    Mick
      You might need a new belt...do a search on the 'endless air' and you will find somemore info.
      Have you ordered yours yet? What about the bracket?
      Now for belt length. I've used a 1935mm belt which is approx 300mm longer than standard (from memory).
      Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
        Mick, your a life saver - thanks a heap. Mind you the instructions seem a bit Chinglish to me but I feel a bit better prepared to give it a go now.
        Endless air is fair bit trickier than I expected - have 6PK1940 belt for it. Moding a bracket over the next week or two, just a warning to those out there - the Hilux D4D bracket from endless air does not fit without some tweaking, good place to start from though! I will post that under the Endless Air Thread when I get it all up and running.
          Mick
          G'day MickL, like DocK I am putting an endless air type compressor on my 150. The info you sent way back when appears to have been moved. Can you please repost it. Am almost at a point where I can start putting up some info for the 150 diesel for those who may be interested.
          thanks
          Geoff
          Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
