Thanks Piggy. I am a qualified mechanical engineer but that often doesn’t cut it as they want a mechanic. My local mechanic won’t do it as he doesn’t want to be dragged through the courts but I will contact the NRMA as they shouldered some of the costs of the transport home.
2nd Engine Failure, I am mystified!
I wouldn't be putting it back together until the NRMA have had a look and a third party has notes of whats going on.. If you rebuild it and start it, you make yourself liable for any further damage. The Engine builder will use that as a method to walk away from it.
Thanks Piggy, I haven’t heard anything from fair trading as yet and to be honest didn’t expect to get anything out of the rebuilder but I wanted to get them on record. The NRMA legal service suggested I would need to prove they didn’t do the oil nozzle up properly. There are probably a million ways to get out of that one.
So I decided to put everything back together and was a little surprised to find all the nozzle bolts just finger tight. The big day arrived and I was devasted but not surprised to find a knock in cylinder 1 when the engine was started. I swapped injector 1and 2 and the knock still persisted. I used the Techstream software to turn fuel supply to cylinders on and off to narrow down to cylinder 1.
I have decided to have a go at selling it as is because other than cylinder 1 it is a great car. It has a electronic diff lock, Recaros, winch etc. I will be posting on the for sale section shortly.
Wouldn't sell much except for parts. The cost of a replacable engine is expense.
Better to sort it out and keep it, but failing to force the mechanic to pay for it is a waste.2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
If you have done 80,000 kms since the rebuild I would be very surprised if you are able to get the engine builder to acknowledge loose bolts/nuts from assembly.
If it is a great car perhaps do the sums to put a new engine in compared to buying another Prado.
Lee
Update. After having no luck with the fair trade case I have had to pull the engine. Everything is great except piston 1 is stuffed and cyclinder 1 is scored. Can anyone recommend a good machine shop in Sydney or surrounds? All I need is cylinder 1 done due to the unusual nature of the failure.
Update. After having no luck with the fair trade case I have had to pull the engine. Everything is great except piston 1 is stuffed and cylinder 1 is scored. Can anyone recommend a good machine shop in Sydney or surrounds? All I need is cylinder 1 done due to the unusual nature of the failure.
