Serpintine pulley beaing's ( aftermarket )
  • Serpintine pulley beaing's ( aftermarket )
    Hey Guys, this is my first post hope you's can help.
    I was just wondering if you can buy aftermarket bearing for the serpintine belt pulleys on the 1GR-FE engine, I was told that toyota had a patent on the bearing and no aftermarket company was producing them, hope this isn't true as the genuine bearing/pulleys cost an arm and a leg. Any help would be great Thanks
    Re: Serpintine pulley beaing's ( aftermarket )
    how much were you quoted for genuine parts? ive been told 3 pulleys are $80 each and one of them is $200ish
    [size=2][color=#00BF40][b]2003 120 GXL V6 auto[/b]. GME TX3440 and AE4703, Mickey Thompson ATZ 4 rib LT265/70R17 plus roadies, Ausguard cargo barrier, BD bash plate, OME lift with Sport shocks. And hopefully more to come, slowly slowly...[/color][/size]
      Most of the original pulleys for most makes are made by Daiken in Japan.
      Maybe that's a lead for you?
        I think Justo found some after market bearings for this. It was a while ago though .
          I couldnt source these bearings (couldnt get one with the right I.D) a year ago for my idler pulleys so I ended up making a spacer myself and so did a few other PPs.
          CBC bearings in Perth (Malaga) said they were in the process of making the whole pulley for the 120series like they have done for many other makes.
          White 2003 V6 GXL, 4spd auto, Vapor injected LPG, Autocraft Prem Billstein 2inch lift with poly air-bags
            I've still had no such luck in finding any so i think i will make up some spacers to as $13 is better then $94 each
              Bump..!! This LINK will help you out with your idler pulley bearings.
              And I still have 2 or 3 sets of bushes if anyone is chasing some.
              03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
                If anyone in Melb needs some I still have 3 sets that I got from Justo, a while ago
                cheers
                December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
                ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
