Prado 120 V6 blue smoke on startup
  • Prado 120 V6 blue smoke on startup
    Hi There
    I have a V6 PRado 120 series and 3 out of 5 mornings on a cold start I will hav a puff of blue smoke, does not use oil , no smoking when driving , only cold start.
    Toyota said its the airflow sensor that needs cleaning and its fuel not oil, ???
    Any ideas
    Dewald
    Re: Prado 120 V6 blue smoke on startup
    sounds like a small leak in the valve stem seals that occurs when the vehicle is stationary for a while (e.g. over night). I wouldn't worry about it if it only occurs at start up.
    Black 2003, TD, GXL Prado
      FIrstly a couple of questions: How many km's has the vehicle done? What oil do you use? Service history up to date?
      As has been suggested, blue smoke is a sign that engine oil is entering the combustion chamber, probably through leaking valve stem seals. It may be worth your while having the motor inspected as the problem will only become worse over time. When the problem gets worse you will notice oil consumption increasing between fills. I've seen diesel motors run with leaking valve seals for a long time before they were pulled down. You've got to keep an eye on the oil level though! An ounce of prevention is worth a pound of cure in my view.
      2004 GXL V6, 5 Sp Auto
        I agree with the above.
        You will soon have damged valve seats which will only get worse. What's a head job worth on a V6???? Thousands probably. $$$$$$
          Acording to your Toyota man it should be an easy fix then. Clean the airflow sensor and see what happens. Personally I go along with the oil getting by the valves theory like the others.
          Brett
          2001 GXL.
            I have cleaned the sensor and the smoke was still there.
            Then I went on a trip of a bout 1500 kom about a week ago and since then no more blue smoke on startup?
            I was also towing a 500 kg trailer and the Prado used no oil. Normally I only do very short trips about 2 km daily. The vehicle is not even porperly running hot during this trip.
            Could these short trips cause some sort of build up which caused the smoke ?
            Regards
            Dwald
              Yep.
              Carbon buildup around the valves and seats. You have probably given in it the blow out it needed with the big trip.
                Can also be a build up of gum around the rings, allowing oil to sneak past them.. Nothing like a good run to clean out an engine!!
                I have been using an oil flush with my oil changes and have found the engine runs better and more efficiently after doing so, my mechanic put me on to it, hes been getting some great results, including his father (also a mechanic) who was ready to rebuid his hilux due to compression readings being uneven and low. His father laughed when he suggested using the flush. He gave it a go, compression is good and no rebuid!!
                Matt
                  What's the product you were recommended Matt? Did you notice much junk coming out of the oil when you used it?
                  I've often thought of doing an engine flush myself but have heard conflicting stories about its efficacy and safety - so I have baulked at the idea. Another method involves running ATF or diesel in the engine oil to clean the gunk out. Presumably this is done without load at idle, as neither products would lubricate the bearings particularly well. I tend to think that regular oil changes with a good detergent package engine oil should keep things pretty clean. The Hilux story has me interested though.
                    I use Wynns engine flush, but there is a couple of similar products on the market.
                    Wynns
                    Didn't notice any Gunk, but tolerances are some fine these days, that only a particle of soot or gum can start to clog up.
                    Matt
                      It's interesting reading this. My 90 series has just come back from an engine tear down, clean, parts replacement and rebuild. Before the fix it was blowing so much smoke on start up that I could sneak out of the carpark without being seen. Since the fix, in the mornings, I get a 'puff' of blue smoke (maybe 3-5 secs worth) then it runs fine (no smoke whilst driving). After the drive, turn off the car and if I start is again within an hour or so not problem, but if I leave it a few hours there is the smoke on start up again.
                      [b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
                        Now I would be concerned about this if I were you given the recent rebuild . Is there a warranty for the work?
                          There is a 6 month warranty on the job. It is due to go back to them in about 400km for a 'first service'. Might have to have a talk to them me thinks.
