Glovebox Removal
  • Glovebox Removal
    Is there anything to watch out for in removing the complete glovebox?
    I notice that there is mechanical lid stop on the left hand side & some sort of cord on the right side.
    It also appears that there are only 3 screws holding in the complete assembly?
    Thanks.
    Been a while since I removed mine but it was an easy thing to do. There used to be a thread on this somewhere, might have to have a look in the Archive.
      Now, tell me why would you be wanting to remove the glovebox??
      Ex 1988 Mitsubishi Pajero V6
      Ex 1986 Suzuki Sierra
        To access the cabin filter and do a good dust cleanup.
        [COLOR=#000080]Nick[/COLOR]
          I removed mine to route my coax for my radio and whilst I was in there cleaned the air filter.
          Andrew
          2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
          [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
          [B]Bitumen - A blantant waste of taxpayers money![/B]
          [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
            I just drop the door off by squeezing the tabs on each side and removing the little springy retainer from the RHS, which gives access to the filter from memory
            Confidence - The feeling before you fully understand the situation
              Originally posted by LeighW
              Ditto,
              To run cables for radios, dual battery & fuel filter water detector to name a few.
              LeighW
              Correct Leigh, actually ro run cables for the UHF & to fit a DP Chip.
              I though I had left all this craziness behind when I sold the Disco II & bought he Prado, obviously not!
              I reckon I had the whole thing about 3/4 out all except for down the left hand side. Are they for real when they say that sill trims & side panels etc have to be removed?
                I just popped mine out after removing the cord thingy and the tray thing underneath (one screw), I didnt remove anything else????
                Then just snapped it back in?
                Didnt touch anything else at all.
                1coolbanana
                  Did you just remove the glove box itself, or the whole assembly?
                    1. Open glove box.
                    2. Release the retractable cord on the side but pulling the end of it out of its holder.
                    3. Squeeze in the sides.
                    Done
                      1. Open glove box.
                      Done
                      Thanks, but I am wanting to remove the whole thing, not just the lid/door.
                        Sorry for incorrect info above, no need to remove sill trim or kick panel,
                        I thought from memory kick panel fouls under cover but it doesn't.
                        So as others have written:
                        Remove screw holding under cover, grasp cover and pull down to release spring clips,
                        lay cover down and unplug modules.
                        Remove glove box left and right lower screws.
                        Remove upper screws.
                        Grasp glove box and pull out, it will take a little effort as there are spring clips.
                        Unplug light, switch mech and airbag cables.
                        Done!
                        LeighW
                          Done!
                          LeighW
                          Thanks Leigh, I had almost put it in the to do later file!
                          Does the silver painted trim above the glove box have to be removed?
                          Shaker
                            yes
                            hisham
                            [COLOR=blue]2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.[/COLOR]
                            [URL="http://www.fuelly.com/driver/hisham/prado"][img]http://www.fuelly.com/smallsig-metric/52690.png[/img][/URL]
