Broken Tow bar
  • Broken Tow bar
    Has any won broke there Toyota tow bar, my has creaked where the tongue fitts into the bar. Never got photo before toyota replace under warrranty, lucky in happen in the frony yard and not when drive on the highway
    Kevino
    This is a know issue for the stock towbar especially when using a Weight distribution hitch, just google toyota tow bar problems and you will find alot of problems, I would get rid of it and replace with a Hayman Reece Bar.
      Here is the existing thread discussing Toyota towbar failures http://www.pradopoint.com/showthread...Towbar-Failure
      I'd be interesting in hearing whether or not you have been using a weight distribution hitch.
      Leachy
      EX-Prado Owner
        I would not trust these at all.
        I brought my car second hand and are unsure what the previous owner was towing with the tow bar.
        I will be removing the Toyota bar and replacing with a H/R before I tow anything with it.
          Thanks mate fvor the info I have been to a local towbar supplier and they also have a pile for failed Hayman reece bars as well
            Hi Leachy
            yes I have been using a WDH hayman Reece 800 lb unit
            Kevin
              The common thread in all the broken Toyota tow bars that I know about has been the use of a WDH.
              Leachy
              EX-Prado Owner
                and non-OE hitch i.e. HR hitch
                  so if i just use the toyota bar with toyota ball etc from new and no wdh/bars etc i should then be ok (???)
                  [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
                  ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
                    I am not aware of an OE bar failing when used as per manufacturers specs
