My KZ-TE diesel radiator leaks/weeps on the lower side above the drain tap. I've had this before on a Falcon where the cheap and nasty plastic tanks are clamped to the core. I fixed this by working on the line of clamps with my multigrips.
The Prado has a similar set up, has anyone tried to use a little force on the clamps to stop a leak?
I am reluctant to pour stop-leak into the radiator to cure the problem
