Front Interior Light Removal...HOW!?
  • Front Interior Light Removal...HOW!?
    Sorry if this has been covered somewhere, maybe someone would be so kind as to tell me where to go...to find it - that'd be great! I've searched (all day nearly) through the discussion threads and tried the forum search thingy all to no avail and as I mentioned in another post about manuals, the Ellery's manual that I have isn't worth the paper it's printed on! So, I thought, 'How hard can it be?'... well, I reckon I spent about an hour on it (managed to get the light covers off and the switch surround - which is handy to know) but I could not get it off. There must be some screws somewhere or it must need to be levered in a certain direction or something, but I think I would have ended up breaking something if I didn't stop. SO PLEASE SOMEONE HEEELLLPPP!!!!
    I found loads of threads telling how to do it, this is probably the best I could find in under 2 minutes http://www.pradopoint.com/showthread...console-wiring pictures tell a thousand words.
    Type Pradopoint.com: then whatever you are looking for into Google, much better than the site search function.
      thanks AJ. cheers samo
        Thanks AJ, I did see that thread, but as I was looking too quickly trying to search through so many, and I didn't read far enough...doh! But I will keep in mind the tip on searching. Thanks heaps PP.
          Another good tip for searching, lots of people put links in to other threads, just as I did above. When skimming through threads that are not quite what you are after keep an eye out for the links, sometimes following 2 or 3 links through different threads will get you where you want to go.
