Hey bush mechanics
Got a 1KZ 2003 model.
Over the last couple of months, have noticed a quick squeal that last 1-2 secs, every few minutes while driving. Air con is still working fine, as is everything else.
My thoughts are that it might be the clutch in the air con because of the cycling pattern. I figured that if it were the bearings it would be more constant?
I'm open to your thoughts and suggestions (within reason!) If you can explain the basic mechanics of the compressor/clutch even better - what would cause the noise, what $$ is a repair/replacement likely to be etc etc.
Thanks in advance
Andrew
Thanks in advance
Andrew
