Painted rims
  • Painted rims
    2 pac paint or powdercoat
    Hi all i was wondering if anyone has any experience with painting or powdercoating rims,, i want to get my standard prado rims blackened,, anyone got any advice, tips or photos,, cheers
    The paint I used was White Knight Squirts readily available from Bunnings in metallic charcoal with a clear gloss top and prepped with etch prime. http://www.whiteknightpaints.com.au/...ative/squirts/
    Process, I painted a spare set of rims so they had no tyres fitted.
    Step 1 – give the wheel a good wash with hot soapy water
    Step 2 – use 800 wet & dry sandpaper to key the surface
    Step 3 – ensure the wheel is totally free of scratches/dents, if not keep sanding
    Step 4 – give the wheel a good wash with hot soapy water
    Step 5 – mask up the wheel as appropriate, if you have a tyre you’ll need to mask up the tyre
    Step 6 – clean the wheel with prepsol or wax/grease remover, keep fingers off the cleaned surface
    Step 7 – lightly cover the wheel with primer, I used etch prime as I have some bare alloy
    Step 8 – wait 1 hour then lightly cover with a colour coat
    Step 9 – wait 24 hours and inspect, any drips or marks lightly sand with 800
    Step 10 – spray another colour coat, this is the last colour coat so make sure no runs
    Step 11 – wait 1 hour then apply a coat of clear gloss, make sure if you use enamel colour use enamel gloss
    Step 12 – wait 24 hours then apply another coat of clear gloss
    Step 13 – wait 48 hours then take of the masking
    Step 14 – marvel at your handiwork
    I bought a 2nd set of centre caps and painted them also with the same method after I keyed them with a scotch pad.
    I also found painting in the shade with an ambient temp of 20-22 was the best.
    D4D
    Addicted PP Member
      Great result
        Thanks d4d they look sick,, i will give that a try when i get the chance,, good detailed instructions.
          [QUOTE=D4D;372395]The paint I used was White Knight Squirts readily available from Bunnings in metallic charcoal with a clear gloss top and prepped with etch prime.
          Hey D4D,
          Great look - I have been working up the courage to do this to mine for a while but been a little tentative as I was not sure how they'd look. You have allayed my fears.
          I would prefer to paint the whole rim like you have but was also thinking about tyre fitters and their use of weights.
          I note you have weights on the outside of your rims. Have you had them rebalanced after the initial fit & balance & if so did they require a touch up? (the rims not the tyre fitters)
          I was contemplating leaving the outer lip so that when balancing if the tyre fitters needed to attach weights to the front face the weights could possibly be relocated without damaging the face paintwork. (problem then is that the colour coded look would be compromised).
          Thoughts/experience?
          Cheers.
          Rod
          Rodolinski
            Mine were sandblasted, primed and then painted with satin black enamel with hardener in it.
            Couldn't tell you the exact process because the old man did it for me but I'm very happy with the result.
            Cheers, Josh
              Hardener ... Thanks Josh :-)
                I am yet to get the tyres rebalanced, if the paint comes off I'll give it a quick touch up.
                  Why not get stick-on weights? Give a much cleaner look...
                    I prefer the balance from clip on as you end up using less weight due to the weights being on the edge of the rim.
                      I painted my 80 series rims which are my fun set with metallic black and two pack clear. I'm happy with the result. The only problem is by the time I've driven down the end of the dirt road I live on they just look plain black
                      Ps. Remember to clearcoat the inside of the rim first then the outside - otherwise you'll end up with a dull dusty finish on the outside that you will need to polish.
                      Cheers, Ben.
