Is the Vanguard the New Model Prado Replacement.
2007 150kw Prado VX D4D, 5spd auto with steinbauer p-box, taipan exhaust, rear dust guard, bonnet protector, factory removable towbar, underneath mounted spare wheel, polished soveriegn Bullbar, Bridgestone D694's, Sandgrabba mats and Panasonic DVD /TV stereo sound system.Tags: None
thanks must be the new model Rav4.
Front picture may be the look off the new model prado yet to come.2007 150kw Prado VX D4D, 5spd auto with steinbauer p-box, taipan exhaust, rear dust guard, bonnet protector, factory removable towbar, underneath mounted spare wheel, polished soveriegn Bullbar, Bridgestone D694's, Sandgrabba mats and Panasonic DVD /TV stereo sound system.
That is definately a Rav 4, with a different front end and no spare wheel on the back, not sure what they have done with that.[b]Rob[/b]
It looks like its designed for the black top only, a bit flash on the interior to take to a dusty & desolate area & get back again in one piece2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
Straight from the horses mouth .... a Japan only, compact SUV, fitting between the RAV4 and the Kluger (if you can believe Toyota press releases)
The Toyota Vanguard is a compact crossover SUV that released in Japan on August 30th, 2007. It is sold in five- and seven-passenger versions and based on the third-generation Toyota RAV4 with a long wheelbase. The Vanguard slots between the RAV4 and Kluger
As it is often the case in Japan-only vehicles, the Vanguard comes loaded with high-tech gadgets, including steering-assisted stability control, keyless entry and satellite navigation.
Manufacturer: Toyota Motor Corporation
Production: 2008-
Predecessor: Toyota Kluger (5-Passenger Version)
Class: Compact crossover SUV
Body style(s): 4-door SUV
Layout: Front engine, front-wheel drive / four-wheel drive
Engine(s): 2.4L I4, 3.5L V6
Transmission(s): 5-speed automatic, CVT
Length: 179.9 in (4569 mm)
Width: 66.9 in (1699 mm)
Chippy
Certainly doesn't look all that attractive to me. I hate the look of the new Rav and Kluger but the 200 is very slooooowly growing on me.Regards,
Big Fella
2007 Prado GXL D-4D Auto. Black. Cooper ATR's, ARB Bull Bar, Safari Snorkel, ARB Dual Battery, Sandgrabba Mats, Black Duck Seat Covers, Plastic Bits on the front, Mesh Grill Guard, Tinted Front Windows, Towbar, Reverse Sensors, Lightforce Blitz 240's, ORS Drawer System. ScanguageII, Stebel Truck Horn, Icom 440 UHF Radio and BIlstein/Ridepro Premium Lift Kit.
If you can't fix it with a hammer...... you have an electrical problem.
[img]http://img.photobucket.com/albums/v655/pradovx96/Web%20photos/emailsig.jpg[/img]
