  • Fitted the new mud flaps (finally), swapped the Optima batteries around, oil change and new filter for the Racor.
    • Originally posted by Beach View Post
      More information?
      Preparation?
      Method?
      ...etc?
      Preparation is minimal, just remove any loose dirt or anything flaking, pressure wash would be ideal.
      Best applied with the correct body Schutz spray gun, this stuff is really thick and gooey so would block a normal spray gun. Obviously you need a compressor as well.
      Really just a point and shoot job, cover or mask what you don't want covered and go for it.
      • Installed a GME tx3340 only to find it didn't work so pulled it out. Installed a reverse camera, and installed a rear work light bracket to space the wheel carrier out.
        • Pulled out single rear seat seat and made brackets to secure 2nd Engel behind passengers seat, and did a test fit of all the camping gear in the back.
          Fitted 2nd 12 volt outlet in back of centre consol for running various appliances and chargers etc
          2 weeks until leave for Mitchell Falls
          Daz
          2004 TD GXL Auto Prado
          • Hey Daz, gotta pic of the 12v power? What did you link it to?
            Cheers, Leon
            Optix Photographix
            • Bought two new batteries. Installed cranking battery. Started removing excess wiring and figuring out how to wire aux battery into the back.
              (Complete re-wiring needed due to the stupid way the previous owner decided to install the second battery. He insisted he was correct despite killing four batteries)
              • As per my build up, installed a LED Lightbar.
                • Originally posted by Snaga View Post
                  Hi Snagga
                  I ran Aux power into the centre consol ages ago, but only installed 1 x outlet. Dont know why I didnt fit 2, as kids have often wrestled to use the power on longer trips to charge gadgets etc, so thought would do it now even though only 1 x daughter coming on our Gibb Trip. Finally got around to it.
                  Its supplied from an Aux power relay from 2nd battery that also supplies rear inside Anderson plug for Inverter, rear external Anderson plug, 2 way and rear Engel supply plug.
                  I have a 2nd Aux relay that supplies 2nd rear Anderson plug for camper.
                  All done in 6mm cable
                  Same relay supplies this plug and the Anderson plug for inverter
                  Finally, also installed a cheapie 3 way outlet for our phones etc. Just used velcro to secure as will only be for this trip.
                  I like having plenty power options on board
                  Daz
                  • Fitted my light bar 33inch Britelight,
                    Big Thanks to Our Sponsors
                    • Finally got the ticking noise fixed - Leaking gasket between extractors and cat.
                      • Originally posted by big-trev View Post
                        Can I ask how you ran the cable?
                        • finally fitted my ARB LED indicator/parks into the bullbar. Discovered cracks in the lower mounting tabs on cover plates under the wings of the bullbar so got them welded today.
                          • Fitted my synthetic rope and alloy hawse
                            dropped number plate bolt into bash plate area.. that can wait for the weekend...
                            • Where did you get your Offset Hawse from dj? (& how much?)
                              • Finished my awning and Maxtrax holders and resprayed passenger side silver panels around air con etc as a car air freshener leaked and ate the plastic.
                                Before:
                                https://dl.dropboxusercontent.com/u/.../Resprayed.jpg
                                After:
