  • Nice work mate
    Sent from my SM-J110F using Tapatalk
    Rig build here
    • Cheers Matt thanks for the recommendation on them. Made getting them so much easier. Next on the list Bash Plates need to protect its vulnerable bits
      2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
      • Single locked, i had existing drivers door damage from another track so i figured "why not"
        and managed to do it with all but a bent exhaust tip and popped out rear bumper.
        unedited vid here:https://youtu.be/F5Er8AanDrI
        • Fitted some high temp lock nuts as I lost the nuts holding the dump pipe to the exhaust this morning. Lucky it was an easy fix as the bolts are welded in on the Genie dump pipe. It happened in the CBD during peak hour this morning, sounded like a tractor and had no torque.
          • 150,000km So changed oil and filter and pumped grease into the propshafts.
            Strange thing is, I only got 3.2L drained from the engine and filter. Where did the other 2L go? Pretty sure I normally slightly overfill it as well and the leak at the timing cover plate shouldn't be leaking as much as 2L... Something is leaking power somewhere
            Wtrxprs007
            • Did you warm the engine first?
              What was the level on the dipstick before you drained it, and has the dipstick level changed since you last filled it?
              • I always change my oil on a cold engine. It's amazing how much oil sticks to the internals when warm.
                BiLLz0r
                • Originally posted by photoprado View Post
                  i did the oil change after grocery shopping with the rents. I did leave it to cool down for about an hour.
                  Before i I drained it, there was not much oil holding onto the bottom of the dipstick. As said in my last post, I always slightly over fill it so it was just above the top dot when I filled it.
                  Originally posted by BiLLz0r View Post
                  I always change my oil on a cold engine. It's amazing gow much oil sticks to the internals when warm.
                  I usually do it that way too. Normally during the weekend after the car sat overnight so all the oil is in the pan.
                  Castrol magnatec or whatever oils that advertise itself sticking to the internals isn't good for warm engine oil changes eh :lol:
                  • Didn't do it today but on Saturday changed my alternator for the 5th time.
                    • Are these the TJM steps or from somewhere else?
                      • Originally posted by fatboydave View Post
                        If you're referring to wsp's post, I think they are AJ120's sidesteps/sliders.
                          Yes mine are from AJ120
                          • Replaced the water pump today. What a job!!!!!
                            • Originally posted by TurboD4D View Post
                              Well done, how old / how many km has your prado done?
                              2009 120 GXL D4D, TJM Bull Bar, Winch, Safari Snorkel, ARB Lift, ARB Lockers, Black Widow Drawers
                              • Originally posted by Mule View Post
                                Its a 2007 done 228k but the pump was changed at 96k the one I pulled out was a GMB brand I think. I put a OE one back in.
