  • The 3m awning has two!
    • I always angle my awning downwards at a reasonable angle when expecting rain so it kind of defeats the need for that arched bow.
      • for those unexpected overnight rainfalls
        Hard to be expecting rain when it's unexpected Bushbasher !
          When I'm camping I have my awning out with the Oztent at the end as it fits perfectly between the poles so I am unable to angle it down one side enough to stop the pooling. This easy solution rectifies the issue.
          • She got new plugs put in. Old plugs were Denso ones last changed by dealer. New ones are NGK.
            Now to see if my economy gets any better than 18L/100
            Old plugs. Number 6 looks oddly wet to me... The rest look the same and good.
            Also so the golden colour on coil 1 and 2 is odd as the rest are still reasonably gray.
            • Today I had the injectors replaced and the EGR system cleaned by the expert! I witnessed first hand #############'s knowledge of and attention to detail regarding all things associated with the 1KD-FTV engine.
              Thanks #### for the hard work, advice and diligence with this job.
              • Replaced blown left headlight globe. Such a bugger to replace as have to remove the battery to get my dainty hands onto the unit.
                  Your'e right there bushbasher. I had to change mine on the side of the road in poor light. I think I used parts of my vocabulary I don't normally use.
                  Greg - 08 D4D Prado,
                  • Gave me the shites because I had the right aux battery out last week whilst doing some maintenance.
                    • Started packing for next 6 week adventure starting Monday. Too bad for all those that have to work, sorry.
                        Good for you, you......
                        • Finally got the correct second hand starter motor, the original Japanese one for Prado, not the little hilux one with a different plug. Now I will spend several weeks reconditioning it :-), once that is done, I will swap it over with the current one, and do the same to the current one and have that as a spare.
                          • Trained a young apprentice on how to change over the rear airbags. Now i just need to add some longer bolts and washers to the sensors.
                              Did the old ones come out ok?
                                lucky they were fixed first
                                would like to been a fly on the wall when you tried to get them out if we didn't find/fix those little welds hey !!
