  • Purchased a 2.5 litre bottle of Toyota long life as I noticed the plastic radiator bottle will below the low line, what an exercise that is, having the radiator cap on the plastic bottle just isn’t the same as a normal radiator cap.
    • Done half a major service lol. Replaced under body fuel filter, greased the propshaft and i've left it sleeping on the hoist tonight draining the diffs, gearbox, transfer case and sump. Will finish service off tomorrow and add the recovery points too.
      LowRange
      • Fitted android headunit and headrest lcd screens for the kiddos for the long trips
        Xerotao
        • Changed out my Redarc Classic brake controller for a Redarc TowPro Elite.
          • Click image for larger version  Name:	 Views:	1 Size:	55.4 KB ID:	737586
            Spent the day yesterday installing a crack in the windscreen from one A pillar to the other due to the cold lol.
            • Picked up the original alloy rims from the powder coater, then had the Duelers put back on them.
              Took off the BFG M/T's for a little rest in storage.
              Current work commitments means little time for off roading and daily city commute.
              Cheers Troy
              • Drove from Perth to Billabong 618ks still over half left on the first tank, heading home, back to work
                • Back home in Karratha, good feeling not to have to fill up along the way. Although there are some strange going ons with fuel ⛽️ gauges.
                  as I said yesterday 618ks still over half a tank, well at the halfway mark gauge rises to full 90 litres left, so as it changed over I noted 830kms, so kept driving and the second tank moves more quickly than the 1st, but I knew I could get around 800ks out of the second tank.
                  so anyone had that before where the gauges are out of whack, bit scary as it was it’s maiden voyage but we got there safely.
                  • When you fill up with 180 liters, the gauge will be on full. It will drop to 1/2 which is the first 90 litre tank complete, then the guage will jump to full again and a green 90L light will come on letting you know you are on the second tank. Then this will go to empty like a normal tank. It's unusual at first, but that's how they work and when you get used to it it makes sense.
                    A ScanGuage is really handy, i run distance to empty as one of the gauges and litres per 100 as another which makes fuel calculations really easy.
                    • Gave the headlights a bit a spit and polish yesterday to bring them up. Turned out better than I expected. Not 100% brand new, but close enough.
                      • Originally posted by tez1 View Post
                        I done the same thing yesterday, polished the yellow out of the headlights. Also washed and detailed the whole car, polished the bullbar, and got the number plate lights working. In an hour shes booked in to get a new front windscreen fitted.
                        • Originally posted by LowRange View Post
                          Yes thanks mate, I found a post on here and worked it out after I had written it, makes sense now
                          • Removed most of my mods over the years ready for sale. It's time to go Prado ;(
                            • Originally posted by BiLLz0r View Post
                              Ok what do you have to offload chep then
                              • Fitted cowhide leather steering wheel with the needle and thread as the top of my wheel is a bit worn, come up very nice, this is the Ebay item number if interested 223025255400, sent from China with auspost tracking and fairly quick delivery.
