  • Originally posted by joel231 View Post
    when i ran it in my dads prado, i did through the firewall and under the door trims and then out a grommet at the back to the towbar.
    CHeers Joel
    I ran mine the same way. All the trims come off easily and reckon there is less chance of damage with the cable run inside the car.
    Cheers Matt
    Rig build here
      Alternatively run it parallel along the brake lines on the left inside rail. When you get past the rear axle you can cable tie it to the rear tank and this brings it right up to the bumper.
      I believe mine got ran this way but was zip tied to the rail, not inside rail where I'm lead to believe there are a lot of sharp edges?? Anderson plug was screwed into the the thin metal plate underneath towbar using stainless steel screws.
      Used http://www.springers.com.au/product/...railer-Housing for Anderson Plug and convoluted flexible tube to house the cable to the rail and inside engine bay.
      macaroon1
      • I didn't mean inside the rail, along the top and inside edge where accessible. Same attached with cable ties.
        • Yep that's what I did Dave. Cheers.
          Took a while to get it over the fuel tanks but I got there.
          Whilst under there I found the fuel tank breather,miso I decided to extend it at the same time.
          Whoever has been cleaning my car hasn't gotten all the dirt out from underneath ☺️ got so much in my hair and eyes whilst crawling around under the car.
          I didn't finish wiring up the power in the engine bay as I pulled the batteries out. I'm intending on rewiring all my accessories into a fuse block tomorrow. And I've got some more stuff to add in as well. At the moment it's an absolute mess as I've pulled it all apart.
          Blake
          • Here's some pics of the fuel tank breather. I broke the t piece as it was stuck on quite firmly seeing as it hasn't been touched for ten years. I used 1/4" fuel hose to do the job. Bought 2m and I've got about 40cm left.
            Blake
            • Finally got around to fitting the new auxiliary battery tray.
              Before:
              After:
              Not quite 6 years out of the first one. I've never drowned it in salt water so don't know why it rusted out so much.
              • And now to fit this. Might wait until the weather cools off in 3 or 4 months time!
                Such a tiny box. I was expecting something, well, bigger.
                • Fitted some ARB UVP
                  A comparison to the original
                  All fitted up finally, scratching under the car ( thank fully I'm a skinny)
                  • Roughly how much did the bash plates set you back Kimbo and do they come in any other colour?
                    Graphite 2013 "Altitude" with an expanding wishlist.
                    • Nice one Kim 👍 surprised you lasted so long. Did it marry up to the front plate ok?
                      Blake
                      • busy day for me today spent time and money on it i got myself a set of HID spot lights and a 22 inch led bar then decided that wasnt enough so i went and gotmyself a duel battery system and a new waeco fridge freezer
                        • Wagon man - not much change out of $500 though didn't barter and not grouped with other ARB goodies, suggest is only colour
                          "Finished in a hard-wearing silver textured powder coat" here ARB link
                          http://www.arb.com.au/products/arb-p...ction/5421100/
                          Blake - after not getting the # plate I wanted, $$$ burning hole in my pocket and yeh lined up well on the AMTS radiator plate
                          • Originally posted by 120_GXL_SA View Post
                            Definately getting well set-up
                            • used my endless air system for the first time ( mind you it's just jury rigged to make work ! )( as we rushed to get to a short trip to the sand down south)
                              worked really well, pumped up all 4 tyres from 15psi to 38psi in just a few minutes, even managed to help a couple of other that were still on their 2nd tyre
                              best score i ever got from a fellow PP member
                              thanks Doc
                              now to get in and wire it up properly with the other switches i have to fit as well !
                              • and another day spent on the preado everything is al wired in with custom brackets to mount the led bar on the bull bar and i decided to make a whole new wiring loom for the duel battery as i didnt like the one the kit came with ill get some pics up soon just gonna rest infront of the aircon for a while
