Vibrating Noise when turning right
  • Vibrating Noise when turning right
    Hi Guys,
    Seeing if anyone can help me out with this issue I'm having. My car is a Prado 08 D4D.
    When I am at speed mainly between 80-110km/h there is a noise which comes from the front which sounds like a winding/grinding noise and it also sends vibration through the car.
    The funny thing is it only happens when I turn right, As soon as I pull steering to the left it completely goes away.
    This made me believe the front passenger side wheel bearing was shot as it only happens when the weight is transferred to that side. So I put a new bearing but the noise is still there and didn't fix the issue.
    Anyone else had a similar problem like this and can assist me in troubleshooting the problem.
    Thanks.
    you turn corners at 80 - 110 km/h ?
      I usually employ the old Scandinavian flick to achieve that.
        hahaha, not necessarily full lock right, but yeah when turning the slightest amount to right the noise is there and loud.
          Are you running muddies. It could be them.
          Greg - 08 D4D Prado,
            No muddies. I even changed tyres recently and this didn't change anything.
            I'm going to change the drivers side wheel bearing next and see how that goes
