Engine running rough after new oil and spark plugs
  • Engine running rough after new oil and spark plugs
    Hi can anyone offer any suggestions? 120 series Petrol Grande.
    I have just changed the oil and new spark plugs. Have done it before on other vehicles but first time on my prado. When I start the car idle is very rough and it fluctuates between 400 RPM and 900 and there is a very strong air pressure sound coming from around the throttle body/ manifold. I have checked that all the plugs are tight and have checked the oil qty level all good.
    Regards, Troy
    Silver Prado 120 Grande 4.0 V6 | Sovereign Bull Bar | 2inch Lift, Front: Bilstein BE5 A712/King KTFR 101, Rear: Bilstein BE5 A713/Airbagman OA6011 | Rear DBA slotted Rotors Bendix 4WD Pads | Safari Snorkel | Rhino Rack Heavy Duty Bars and Rhino Rack Tray | Dual Battery and Monitor | Rear ARB locker |BFG ALL Terrain
    Maybe a vacuum hose not back on check all hoses
      Make sure the maf sensor is clipped in properly
        Did you disconnect the battery?
          Yes i disconnected the battery, why?
          Regards, Troy
            It's like the ECU is doing a relearn when you disconnect the battery. The low idle (can sometimes stall) goes away after a while. Could be that.
              It was a small vacuum hose on the rear left side!! Alteast i will be quicker doing this next time haha. It was very hard to see but i must have disconnected it to get to the plugs
              Regards, Troy
