Outer CV boot replacement
  • Outer CV boot replacement
    Hi all,
    Does the bearing housing come off the outer end of the drive shaft so you can slip on a new boot?
    2004 3.0L GX Man 300,000km
    To replace the out c/v boot, remove the shaft from vehicle.
    Remove inner cup, tripod & boot, then you can replace the outer boot.
      Ok thanks mate. Do you think that method of using a plastic cone to stretch the boot on would work?
        You can get special tool & boots to do so. But I have never bothered.
        You will need to do work to remove the shaft, clean & fit new boot, so you may as well do the bit extra its not much.
        The outer boot id stick with genuine, it plastic of sorts, not rubber, they're pretty tough. You can't stretch those.
        If you pm me your details I can contact you & run you through it. no charge!
        Piggy
        Water pistol pilot.
          Good opportunit to clean, inspect and repack the inner CV too
