Hi all,
I guess that we have all seen the photos of the burnt out Prado on the CSR.
As one who lost a month old Range Rover about 25 years ago due to the same problem I am still sensitive to the issue of under vehicle fires. The problem then was the V8 downpipes going over the gearbox crossmember and of course it was a petrol vehicle. We fitted the replacement car with truck type stacks up the side to avoid further problems. But I expect that the local boys in blue might take exception to doing that here.
We are going into spinifex country with our TD Prado and Tvan and I would like to hear any PPers experiences about grass build up under a Prado ie any particular areas etc etc.
We carry 2 9l pressurised water extinguishers and the 100l water tank inside the car is plumbed to a 12v marine deckwash pump attached to a pressure washer wand type hand piece. This allows you to push the wand up under the car if you need to get to a fire source.
But prevention is far better than trying to put out a fire once it has taken hold hence the enquiry.
Mike
Mike
