Hey all, I'm thinking about getting a caravan sometime soon to tow with our 2008 VX diesel Prado. Van will probably be about the 21' lenght and well within the 2500kg/250kg ball weight rating.
Should I be using a weight distribution hitch? If so will this work ok with the Toyota hitch or will I be needing to ugrade to a hayman reese hitch receiver?
Would I be better of with higher rated springs all around?
What is the general feeling out there as I have read about the Toyota hitch receiver failing on some occassions when using a WDH?
