Yep, I know it's spec'd at 180l, but of that, how much is useable? The root of the question, I have a Scanguage and unsure whether to set it for 180l, or whether I should be setting it at 170l?
How big is the fuel tank? - ScanGuage question
Re: How big is the fuel tank? - ScanGuage question
Agree - most tanks will have 10 or 15 l left in the bottom of them - but I'm not sure if the 180 is 180 useable - or based on 15 per tank, 150l!08 D4D > Build Up here > [url]http://www.pradopoint.com/showthread.php?18458-Ivan-s-2008-D4D-GXL[/url]
Canberra
Originally posted by IvanSandersYep, I know it's spec'd at 180l, but of that, how much is useable? The root of the question, I have a Scanguage and unsure whether to set it for 180l, or whether I should be setting it at 170l?[B][SIZE=4]ntp
I'd suggest that Mr Toyota actually did some mathematics and calculated the actual volume of the tanks. Surely, it would be correct +- a litre or two.
Plus you would have several additional litres contained within the filler pipes, fuel lines, pumps, etc. I always fill mine to the brim, I know it takes a few extra minutes but then I can be sure that I have maximum capacity.Dave
Originally posted by BushbasherI'd suggest that Mr Toyota actually did some mathematics and calculated the actual volume of the tanks. Surely, it would be correct +- a litre or two.
Plus you would have several additional litres contained within the filler pipes, fuel lines, pumps, etc. I always fill mine to the brim, I know it takes a few extra minutes but then I can be sure that I have maximum capacity.[COLOR=#000080]Nick[/COLOR]
Hey Nt, Are you saying yours only comes on after 170+ liters? My light comes on at about 150+ liters. That gives me a range of about 300km remaining. I'd be a little concerned if mine came on with only 7 liters remaining.
LFaR.[size=1][color=#770000]29Feb12:[/color][color=#777700]12GXLTD Auto, ARB Deluxe Winch bar, WARN 9.5xp Winch, IPF 900XS, Tow, Safari snorkel, Front + Rear Recovery points, ARB OME NC Sports, ATZ-4Rib[/color][color=grey], Silver[/color]. [color=orange][b]MaxTrax[/b][/color], [color=maroon]ScanGuage II[/color], [color=blue]ARB CKMA12[/color], [color=deeppink]UHF: GME TX3440 AE4018K1 UNH047SX[/color], [color=darkgreen]Bushranger Air Jack[/color], [color=green]Staun + ARB Deflators[/color], [color=brown]WindCheetah Roof Rack[/color], [color=green]Foxwing[/color], [color=red]Super Charge MRV70, Redarc BCDC1220[/color], [color=darkblue]ARB 60L fridge[/color], [color=blue]MSA Fridge Dropdown slide[/color], [color=darkyellow]DRIFTA Drawers[/color], [color=gold]TJM Bash Plates[/color], [color=brown]TG150[/color].[/size]
I have done a search on this as I do remember it somewhere but nothing shows up. The simple question is "how much fuel is left when the warning light comes on?" Is there general agreement on the 15 l mentioned above? I am trying to use up some older fuel in the sub tank and my light just came on after 1070 city km [V6 VX]. Neil
