my 2005 prado was fitted with full ome suspension and from the first moment i realised that the front is too soft and wallowy. the guy from ome came a few days later and admitted immediately that its too soft . in short; after more than 2 years the problem is still there,. in fact, im going to replace the front suspension with TJM system. i believe its a stronger more "heavy duty" suspension. .. can somebody out there give me any advice ppllease !
ome suspension 120 series
Re: ome suspension 120 series
Originally posted by tassie tigerOME makes different spring rates. They have fitted the incorrect springs for your application. A spring change will fix your problem.
When I had my OME fitted, I too worried about the different springs. The fitted stated he would change the springs if I was not happy with the ride after 48 hours use, no charge.[B][SIZE=4]ntp
