DIY Boost Gauge for $60
    Re: DIY Boost Gauge for $60
    I like to know if you guy's get a vacuum reading on the boost gauge? If no, why is that?. I got one installed on my 1KZ-TE, and one of my mate ask me how come my boost gauge doesn't read vacuum?, and I just answer maybe its just a diesel engine different from a petrol engine. Just want to really know what the answer is. Unless there is something wrong?
    If you have plumbed your gauge pre venturi/butterfly plate (intercooler side) then you will not see any vacuum at all read on your gauge.
    If you plumbed it post venturi/butterfly plate (manifold side) you will see approx 5-7 in.Hg at idle and maybe between slow gear changes in a manual also sometimes during decelleration. 5in.Hg is a very small negative pressure (look at the scales on the gauges shown in this thread)
    Diesels generally don't run a throttle plate hence no intake vacuum.
    Some like the 1kz and d4d are an exception to this rule. They run an intake venturi/butterfly to create a small vacuum at idle to draw in large amounts of EGR gasses to meet emissions standards.
    Mick
      Hey Mick,
      Thanks for the info.
      Cheers, chubbo
        Can I see photo of re-plumbed tee section for your boost guage
        Originally posted by samo View Post
        replumbed gauge as mick said and it does reduce needle shake at low boost but i still get shake at idle. thanks samo
        Hi Samo,
        I'm not sure if you're still around and/or have your 120, but I'm looking to install an EGT and Boost guage and would like to know where exactly you re-plumbed the tee section for your boost guage. If you could post a photo that would be awesome!
        2005 Silver GXL 3lt Diesel 5spd Manual,Factory Bullbar & Roof Rack with spare tray,Safari Snorkel, Cooper A/T3,Dark Tinting,Spots, 2" Lift Bilstein/Kings,Airbags,Sandgrabbers,Grill Screen,Bonnet/Front Wind Guards,Sheepskin Covers Front/Second Row,Icom 400Pro UHF Radio,ARB Rear Locker,Big Red Plus underbonnet compressor,Triple Battery underbonnet/rear cargo,Ctek D250S Dual & Smartpass,Synergex PureSine II inverter,Waeco Fridge/Freezer
          Mick
          Hi Mick,
          I'm not sure if you're still around and/or have your 120, but I'm looking to install an EGT and Boost gauge and would like to know where exactly you plumbed the tee section for your boost gauge. If you could post a photo that would be awesome!
            the_tango
            Mick L is now using his business: OziOffroad
            Search for both samo and Ozioffroad and maybe private message them.
