installed boost gauge today, very easy install, takes around an hour
Boost gauge $40 from local spare parts shop and has mulitcolour back light
![](http://i230.photobucket.com/albums/ee3/sambo772007/20032008255.jpg)
the mounting pod cost $10 from supercheap drill holes in back to suit you gauge, this one was a speco brand
[/img]![](http://i230.photobucket.com/albums/ee3/sambo772007/21032008260.jpg)
you also need about 2.5m of 1/4inch vacum hose, and a 1/4 inch T piece. attach to intercooler on inletmanifold side using tee piece.
[img]![](http://i230.photobucket.com/albums/ee3/sambo772007/20032008258.jpg)
run hose along the firewall and through into the cab up to the steering column, i wired the backlight for the boost gauge by taking power off the 10 amp ingition fuse in the fuse box and earthing to the metal in the dash
attach the gauge to the steering column with doublesided tape and the finished product is
![](http://i230.photobucket.com/albums/ee3/sambo772007/21032008266.jpg)
and this
![](http://i230.photobucket.com/albums/ee3/sambo772007/21032008267.jpg)
cheers samo
[/img]
[img]
and this
cheers samo
