Hi
Could anyone see a problem with mounting a air receiver between the chassis rails behind a Sovereign bull bar.
I just fitted the bar and there is heaps of space between it and the radiators so I've made a stainless air tank and intend to
use the mounting bolts that the bar bolts to the chassis rails to mount it. Just not sure with regard to the airbags.
Thinking of mounting the compressor on top of the tank with a pressure switch to control it. simple matter then of fitting the outlet behind number plate.
sparksy
sparksy
