Gordon , $95 per side, they screw on with self tappers ... I was chasing a look, any benefit in protection was a bonus, i look at it as color trim, butane
I was looking at the side of the prado the other day and thinking about this mod of yours butane... If i get a chance I might be adding something similar before the GTG...
If you keep knicjking off for fishing trips it is unlikely you will have enough time. After all we are queuing up already and Loz has threatening to call the police on numerous occassions screamimg stuff like "Move your F%$^en Prados, I nee to take my ids to school!
Hmm, self centred attitude if you ask me. :P
matt & loz... ... love it because its something different than the standard lift,bar and tyres...
I first black out my rig under guards with paint , the flares reversed where fitted , then body sealer ( TAR ).. as advised .. by a PP member
it washes up nice .. and the black bead around the arches,, define when the running gear stops and the body starts .. hope some one else does it so i can see how it looks on someone else's rig... if you do it plenty of picks please ,,
cheers butane
This is an easy, straight forward mod (but I never thought to reverse them).
I put these on an old Pajero years ago, before I saw the light. They are just screwed on with self tappers into the wheelarch's. The hardest part was inserting the wire through the rubber inserts. A little WD40 down the hole and the wire slid in easily enough. The wire rod is used to tension the rubber and keep it's shape.
