I have looked through the 120 Suspension threads and can not find one on this subject. I recently purchased Wholesale Suspension 30mm Rear Extended link pins. On measuring and comparing them to standard pins they are 12.2mm longer. Evidently these extended link pins were developed for the earlier series Prado where they are 30mm longer than std.I phoned Wholesale Suspension and Jason was quick to offer a full refund with freight included. I have no problem with him or his company and this post is not a criticism of this supplier. I am very happy with his service and would have no hesitation in buying from him again.
What I do want is to establish is the best length extended link pin for my 120 Prado to achieve maximum drop in the rear suspension with the lift I have. My Prado is fitted with a 50 mm lift kit of Bilsteins and King springs. Tyres are 265 70 17. I have no intention of changing this setup. As the link pin is located above a rear control arm it I assume it could hit this arm if the link is too long.
This is my first post and this topic is probably covered elsewhere. If so I would appreciate help to find the information. Has anyone already gone down this path who can provide the correct length link pin needed to achieve maximum rear suspension drop for my set up? Also the brand and where to buy these extended links?.
