Front sway bar link failure
  • Front sway bar link failure
    Has anyone had a front sway bar link failure?
    My left hand side failed on weekend whilst on vic high country trip. Didn't notice anything unusual until hearing noise over some ruts on gravel section.
    Bent in halve like banana and then broke at this point. Tore the boot to pieces.
    CASTOY
    2004 KZJ120 Grande Pearl White.ARB Bar,Winch,Safari Snorkel,Dual Batts,DPChip,UHF & HF Radios. Safari Snorkel,17X8 King wheels ,265/70 MTZ. Kaymar rear bar, FourbyFitouts Custom draw system,Cheetah roof rack,Foxwing awning,2" lift,Koni's & King springs all round.
    I have heard of this type of failure before, as you said when they go they take out the CV boots with them. I believe you can get stronger links, but not locally.
      I have heard of a couple of failures, not a lot considering the amount of 120's on the road though.
      If you get stuck, i do have these in stock.
      Regards, Jason.
        Thanks Jason, are yours same as standard?
        CASTOY
          Hi again.
          Mine are an aftermarket O.E style replacement.
          They were hard to track down & i haven't found any better ones as yet in my searching.
          Regards, Jason.
