Fitting Air Bags To the Rear
  • Fitting Air Bags To the Rear
    Gday guys,
    Im looking at fitting air bags to the rear of my 120, I have a 2' lift with medium springs in the rear already.... My questions is do i need to replace these with heavy springs or will the airbags do the job? the suspension is great but sags a little when I'm loaded with gear and the boat hoping the bags will sort this out without having to up rate to heavy and have a rough ride on the tar...
    Cheers for the help
    Rob
    Yep you are on the right track, that's absolutely what helper air bags are designed for, a bit of adjustability when you get loaded up.
      Yeah thought so just wanted to confirm........ thanks for that.
      While your here AJ120 I've got another question for ya........ The rear bar you make for the 120 what is the cost with dual wheel carriers? and what would one cost to be shipped to byron bay?
      Rob
        Have a look here http://www.pradopoint.com/showthread...-Wheel-Carrier for bar price and drop me an email using the address in the first post of that thread and help you out with a freight price.
        AJ120
        Out of control poster!
          Think that link was the wrong one??
            Oops, bloody Ipad, put the correct link there now.
              Oops, bloody Ipad
              Code for; user error??
              Mick
                Mick
                Probably I was selecting the URL to copy but it was pasting a URL I copied days ago. NFI why it was happening so had to get of my butt and walk into the office and use the laptop.
                  JT
                  Hey guys, Are the rear springs remove to fit air bags or do they slot in between the coils?
                    They go inside the rear coil. Only the grande has the full airbag in place of the coil....Cheers Steve
                      You will need to take the springs out and cut down the internal rubber bump stops. Very easy to get the springs out,undo the rear bottom shock mount and jack up the BODY, the spring will fall out when you get the car high enough. You may have to undo the sway bar link as well.
                        You will need to take the springs out and cut down the internal rubber bump stops. Very easy to get the springs out,undo the rear bottom shock mount and jack up the BODY, the spring will fall out when you get the car high enough. You may have to undo the sway bar link as well. Put ... Product Review: Polyair Suspension Assister Airbags in the search box at the top for some good instructions
                          Thanks for that guys, will look at product review.
                            Perfect post - exactly what I am about to do. Thanks guys
                            Prado 120 petrol, TRD supercharger, front/rear airlockers, profender suspension, superior UCA's and trailing arms, 4.56 nitro gears, arb winchbar, winch, ipf spots, 285/70/17 Bfg muds km2's, UHF, awning, steel roofrack, buds sliders, rear drawers, extractors/exhaust, plus a heap of other crap.
                              Just fitted a set of Airbags to the rear of my 120. Fairly easy job just need to make a small bracket to hold the valves. I used Airbag Man at Brendale. Excellent service from these guys.
                              Fitted myself in about 3 hours taking it easy.
                              Rusty62
