150 springs in a 120 ??
  • 150 springs in a 120 ??
    Hi ALL,
    I have a friend that has very limited finances but requires new suspension in his 120.
    Will the original suspension out of my 150 fit in the 120 and if so will it lift the height any or will it stay the same. ???
    I was thinking it may lift it a bit as I believe the 150 is heavier.
    Thank you
    2010 GXL Prado, ARB bar and winch, driving lights, dual wheel rack, roof rack, UHF, sat phone, rear seats removed, custom rear floor and fridge slide, chip, 3inch exhaust, 3inch lift, 200kg rear springs, ome shocks, 285 maxxis Tyres, Dual batteries, Anderson plugs, power in back etc. snorkel, and more. Wish List - nomad transmission lockup, roof mount DVD, long range tank, endless air compressor to fit the 150.
    The rear springs should fit no worries, I gather more than one person has done that. I suspect the fronts would also fit but can't recall anyone doing it. I would also suspect a small lift, but so small you wouldn't do te swap just for the lift.
      Thanks for the info Andrew,
      Sounds like its not worth worrying about then, not worth changing them without getting a bit a lift aswell...
      we will need to think of something else.
      Ben
        http://www.pradopoint.com/showthread...sion-fit-a-120
