Nolathane or rubber bushes?
  • Nolathane or rubber bushes?
    Hi
    I need to replace the rear suspension bushes which is better nolathane or rubber?
    from what I've been able to find rubber seems to be the go with a 4wd just after your opinions
    Cheers Pete
    I think rubber is better with the Prado suspension.
      Originally posted by pete8205 View Post
      Hi
      Cheers Pete
      Rubber all the way, it tends to let the suspension flex better, and doesn't tear like Nolathane, it also gives a better ride over Nolathane.
      If you were driving a 2wd sporty thing, then I would say Nolathane over rubber. But for any 4wd, then only use rubber.
      croozza
        Nolathane is used when you want more handling performance , not 4wding or touring performance . The prado is one of the best riding 4wds ever built . It's ride is one of the most comfortable , yet best handling . Unless you need to make your prado to handle like a Lamborghini , I'd go with the rubber.
          You know what they say "Always wear ya Rubbers"
            cheers guys rubber it is and there also cheaper
            pete
              Hey does anyone know where I can buy rubber bushes Toyota want a lot!
              I've found 1 supplier that can supply the upper rear trailing arms and rear pan hard
              I've found another that can supply the front upper and lower control arms
              cannot find for rear trailing arms
              personally I would prefer to purchase from 1 place
              The reason I'm looking at replacing them is I have the front left upper control arm shot close to 10mm of movement and the lower is not much better, in the rear when loaded it thuds
              I have OME suspension ordered and figured I'd redo the bushes whilst I have it on stands
              cheers Pete
                Amayama?
                  Hi Amts
                  when I first read your post I thought what the f#@?
                  so I googled it, bugger me there cheap there on holidays till the 17th so I have to wait if those prices are genuine its worth the wait
                  the lower control arms bushes are less then half the price of the cheapest I've found
                  cheers pete
                    Yes, they're a genuine site. Several PP'er have bought from them. It is worth it to accumulate several parts into one order to save on postage or combine the order with someone else.
