hi guys
recently took a whack to the passenger side of the 120 - had to replace steering knuckle to fix some serious camber issue now have noticed that there is a bit of slop in the rack (the impact side only) its about 5mm - assume there is some kinda nylon bush inside thats copped a belting - anyone pulled one of these down before? night mare?
car has to go over pits (been sat for a while and way out of rego) - does anyone know if there is an allowance which you are allowed with play in the steering? (WA)
btw - the play is def in the rack, (not wheel bearing or balljoint)
cheers
Bill
cheers
Bill
