Hi all,
I was under the prado this arvo doing an oil change and noticed that one trailing arm(drivers side) has a slight bend in it while the other is dead straight. So here come the stupid questions....
It's meant to be straight right?
Can I take it off and straighten it out and put it back or should a put a new set in?
Any special tricks in removing?
Any new ones recommended? have an ome 50mm lift.
Will this bend put the rear axle out alignment!
Simon
Simon
