Long Story/Dumb Questions!!!
I have a Prado 120 with around 80,000Kms. Have towed a camper trailer for half of these Kms. Unit has always had a sag in the rear end when the camper has been conected. With a plan to go to the Cape this winter,so I thought I'd put some HD springs on the rear without any lift to help with the "Ducks disease".
Arranged to do this at my local springs works. So far so good. Don't need to change stock shockers recommends the spring works prop as they're a good unit he thinks. Day to fit rear HD's arrives and I turn up to get the swap done. Get to the spring works and he cant get "standard height" Lovell HD springs but have found Fireflex. Ok but they've got some lift. ["but they'll settle. Mmmm1!!!?"]
So I say go ahead.
THEY DONT SETTLE!
So I need to put some coils with lift on the front to balance out the nose down effect. Don't need to change the shocks. he says!!
Have now done the front as well.
Now to my Questions!!!!
I expected the ride to be stiffer with the HD coils but this now seems harsh especially on corrugations/bumps [and they say that there are a few of them on the road up to the Cape].
Do I need to put longer shockers on the rear to compensate for the extra 40/50mm lift?
Should I now have to go and change the stock shockers for the appropriate Fireflex units or are the Tojo ones OK?
Will the Fireflex Shockers soften out the ride again?
Any other advice /opinions welcome.
Inland
So I say go ahead.
THEY DONT SETTLE!
Inland
