How do I know its lifted?
  • How do I know its lifted?
    This is probably obvious to most, but we just bought a 2nd hand 2003 T.Diesel which has had the original suspension replaced with old man emu nitrochargers. How can we check whether the previous owner also had the vehicle lifted? I guess what for and where should we look?
    Green Prado KZJ120 2003 GXL 3.0ltr Auto, Cruise Control, Safari Snorkel, Toyo Alloy Bar, Toyo Aero Roof Racks, King Springs (KTRS-102), OME Nitrochargers, IPF Headlights, Dual Battery, Rubber Mats, Cargo Barrier, Wrangler Silent Armour (265/70R17), Rear Visor, Grille Mesh, Weather Shields.....
    I s'pose the easiest way would be to have a look at the suspension measurements thread and get an idea of the front and rear height readings for the standard height vehicle and the lifted vehicle. Get a bit of a ballpark figure for each.
    http://www.pradopoint.com/viewtopic.php?t=1392
    Then go and have a yours with a tape measure and see whether it falls within the range of standard height of lfted vehicles.
    Very roughly ......
    Approx 750 mm = standard height
    Approx 800 mm = lifted suspension
    Good luck
    Chippy
      Hi toil,
      There is an easier way of telling if your car is lifted.
      If you open the door and see the world like this you know you definitely have a lift kit fitted. :shock:
      Sorry Chippy couldnt help myself :lol: :lol: :lol:
      Cheers Moto
      2007 Grande crystal pearl D4D auto
        ... or you're just very very very short ..... :lol: :lol: :lol:
        Chippy
          Thanks Chippy.
          I have 730mm (front) and 800mm (back), I have an alloy bar, dual battery so it would be standard suspension on the front and lifted??? on the back.
          I need to get under the car and double check everything :roll:
            Far out, It's got that "bum in the air look" going. :lol:
            Can't the previous owner tell you whats been done?
            Mick
              I would reckon its been lifted ... but with light or medium duty springs in the front ... and with the added bar and battery there's every chance that it has sagged.
              Still, if you don't have access to the previous owner ... Matt's idea works well. Take it to a pro. They will be able to tell you quickly and easilly ... and also advise whether the spring rate in the front is too soft for the weight.
              Chippy
                Dropped into ARB, guys were great.
                King springs (KTRS-102), though the front might be sagging a little
                OME Nitrochargers
                The previous owner had Cooper AT 265/65R17's on the rear and 265/70R17's on the front which didn't help things. Replaced the rears with new Wrangler Silent Armour (265/70R17) and while the boots were off had a good poke around to confirm part numbers on the coils and shockers.
                All sweet now.
