A few weeks ago I installed OME 895 springs. The springs were 3 months old, ~5.000km.
After installation I measured the height (ground to body through wheel center):
Right rear: 99 cm
Left rear: 98 cm
It seems that over time the left side sagged a bit further, as now it's only 96cm, while the right side remained at 99cm (Same level of load and fuel, same and even tire pressure, measured on even ground)
-> is there a right and left version of the spring or are they identical? How do you identify L/R? On the tag it only says OME985.
Did somebody experience the same issue? Swapping rear springs is not a big deal, but before I start getting dirty maybe somebody has some hints?
Cheers Wolfgang
Right rear: 99 cm
Left rear: 98 cm
Cheers Wolfgang
