4 inch lift????Anyone???
  • 4 inch lift????Anyone???
    Just found this
    http://www.superiorengineering.com.au/p ... ts_id=8174
    Could there be any foreseeable problems with installing this lift? It has a diff drob kit so would reduce the chance of worn CVs.
    Before the fun police get onto this YES I know it would need a engineers certificate before it beeing deemed legal.
    cheers
    Jonny
    Re: 4 inch lift????Anyone???
    looks pretty mean!
      One of the forum members, Chase.rawling, has installed this gear I believe and followed this up with 285/70(or 75)R17s:
      Fitting 285 or 33 inch tyres
      [COLOR=#000080]Nick[/COLOR]
        Hrmm doesn't look 4"... heres mine with 3" lift and 32's
        [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
          Looking at the photos in the link (first post) and comparing body lines to wheels i reckon the rear lift would be around 4 inches, but the front doesnt look any different to my 2" lift. The photo above looks higher in the front than the one in the link? or maybe i just need glasses :shock:
          A couple of rear coils spacers and 40PSI in the air bags and i to could have a 4" lift to.
            you will have no problems with this type of lift untill you do your first maccas drive through run
            Dont list all ya mods, you will only be more upset when i get further
              I wemt to Maccas once about 25 years ago, never saw a reason to go back again :!:
                Well off topic I know but a couple of years ago I was going to a Parents/Guardians meeting at #1 son's school. The school was just around the corner from work so the idea was to stay a bit later than usual and then drive up to the school. On the way I realised I was a bit peckish so I drove through the local Maccas. Got to the ordering window and perused the offerings. Then told the startled teenager that I couldn't do it and drove out empty handed! Turns out said teenager was the son of a friend (I didn't recognise him in his costume) and he recognised me and told his mum all about it by the time I arrived at the meeting!
                  Could always get a 6 inch lift from the US of A for a FJ Cruiser and cut your Crossmembers etc and fit it.
                  This of course improves your suspension travel over a 3 inches lift by a whopping 0 inches!! Only benefit is you can fit bigger tyres - a modification for "poser" 4x4s.
                  2014 D4D 150 Prado soccer mum mobile
                    Well just devised a lift kit to give me an extra 4 inches of lift, this is ontop of my existing 2 inch lift for a total of 6 inches of lift :shock:
                    Having just removed a wall in the house and placed a 300mm x100mm oregan beam in to support the roof i had 1.5m left, so i decided a set of mini ramps would be a good use for it. I have 1 set of normal ramps but this only lifts one end of the car when underneath, with no ramps its a tight squeeze when using my creepy crawly. With the 4 inch lift though it is now ideal for working under the Prado.
                    Total cost, zero dollars cause i used a left over piece of timber and i got the original beam for free in the first place total time involved, about 10 minutes work
                    Diff clearance and ramp over angles are brilliant now :wink:
                      aj you have 2 much spare time :lol: :wink: cheers samo
                        Hi Andrew
                        You might want to get your wheels balanced as soon as posible after the new lift kit to increase your tyre life. :lol:
                        Cheers Troy
                          4" lift
                          Hi,
                          Just wondering if anyone in the Sydney area has fitted a 4" lift for 120, if so where did u get it fitted?
                          Tim
                            Do a search mate an you'll find info for either the 4" Superior Engineering kit or read Steve's 8608 rig build up thread.
                            JR
                            [I]2005 White GX 3lt 5spd Man - ARB Deluxe Bullbar, Boss 4WD Dual Battery System, BFG ATR, 3 x 9" HID Spots, Raised EFS Suspension, Cargo Barrier, Racing Seats, Oricon UHF, Recovery gear, Side Awning, GXL Rims, Waeco Fridge, Rear Camp Table with Stainless Top, GPS, Performance Chip and much more to come....[/I]
                              4 inch lift eh? One way of keeping the missus out of the car I suppose, she's already complaining about climbing over the steel sliders with a 2 inch lift.
