Does anyone know whether 17x6 steel rims off a 2005 GX will fit a 2007 (update) GXL without rubbing discs, calipers etc? I'm looking at using one for a second spare.
GX wheels on GXL
Yes, they'll be fine. Just make sure that you match the overall diameter on both sizes.
265/65R17 = 245/70R17
The GX was released with 225/70R17 tyres in the early models but they are considerably smaller (by 30mm) than the 2 sizes above.
You can also buy genuine 17x7.5" steelies from Toyota for a pretty good price. Then all wheels will be the same width.
Originally posted by amts View PostYes, they'll be fine. Just make sure that you match the overall diameter on both sizes.
You can also buy genuine 17x7.5" steelies from Toyota for a pretty good price. Then all wheels will be the same width.2011 150series GXL
Originally posted by wooley View Postwhat offset are the toyota steel wheels, Andrew?
ET30 for the 17x7.5"
http://www.pradopoint.com/showthread...ffset-Database
Originally posted by amts View PostYou can also buy genuine 17x7.5" steelies from Toyota for a pretty good price. Then all wheels will be the same width.
Alternatively, I also bought a Speedy Grande alloy from Bob Jane for $165 as a second spare for the car, almost an exact match to the genuine Toyota wheels, you just need to use different nuts which are supplied with the wheels.Justin
2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
