I had to change my first tyre recently on the passenger side front wheel and I'm curious, the wheel once raised did not spin freely despite the fact it was in 2WD, unless the clutch was depressed. I understand that these are not free wheeling hubs and that I guess therefore that in 2WD the wheel turns the whole transmission back as far as the transfer box where it is disconnected from the engine power? Is this correct? Why then could I not turn the wheel in 2WD unless the clutch was depressed??? Can someone please explain in laymans terms?
Possibly a dumb question regarding the front wheels in 2WD?
02/07 Prado GXL D4D 6 sp manual bought Oct 2009 with 43k on the clock. ARB bullbar and Redarc dual battery system, safari snorkel, 2" OME lift, front ARB air locker, Cooper Discover S/T Maxx LT265/70R17s, 17" black CSA steelies, GME TX3520 80 ch UHF, Dept of Interior rear roller drawers, full length Rhino-Rack and Sunseeker side awning.Tags: None
Originally posted by wooley View PostThe prado is a constant 4wd. There is no 2wd.
Sent from my iPad using Tapatalk HDD4D Prado GXL - 2014. 2" OME lift, ARB Deluxe Winch bar, ARB under body protection plates, ARB EZ Deflator, Weaco fridge, Matsen fridge on slide, BFG A/T's, ARB CKMA12 compressor, Oztrail side awning with LED lights PLUS canvas extension, Lightforce XGT's.. Oricom UHF380, GME AE4017
What made you think it was in 2wd?[SIZE=1]Cheers Jim.
[/SIZE][COLOR=#0000cd]
Originally posted by wooley View PostThe prado is a constant 4wdYep.....I have a Prado just like you
Yeah, thx Wooley. I knew it was going to be a simple explanation like that. Just testing to see if you guys were all on the ball! Actually I have now ferreted out the owners manual and read up on this. I had assumed because the dash 4wd light only comes on in HL or LL that in H when the light went off that it was in 2wd. My bad.02/07 Prado GXL D4D 6 sp manual bought Oct 2009 with 43k on the clock. ARB bullbar and Redarc dual battery system, safari snorkel, 2" OME lift, front ARB air locker, Cooper Discover S/T Maxx LT265/70R17s, 17" black CSA steelies, GME TX3520 80 ch UHF, Dept of Interior rear roller drawers, full length Rhino-Rack and Sunseeker side awning.
